Mpc 4500 "please wait"
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Hi Guys,
    I have please wait displayed and the machine will not come to ready, also the fax option is not available, i cannot even access sp mode as it just beeps when i press copy sp. i disconnected the hard drives and it came to ready, i could use the fax mode and i could copy. I am going to swap the hard drives with fingers crossed, but could it be anything else?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • pocket aces
    Ricoh Technician
    • Nov 2008
    • 72
    It' the HDD'S
    • ccchuah
      • Mar 2009
      • 159
      Mostly is the harddisk only giving problem.
      • whatchagot
        try disconnecting the fax module, then clear #2 in sp 5832 then reconnect everything should clearup if not replace hdd
        • knightfall
          • Jul 2006
          • 633
          before disconnecting the fax module its much easier to unplug the hdd first, this will get rid of the please wait and give you the fax functions back.
          Get your facts first, and then you can distort them as much as you please.
          • leeyeo
            i meet few times on field.Normally i will replace the HDD,when it turn to ready,i will connect back the previous HDD~~it works again~~!!90% successful 10 % fail (HDD problems)lolz~~sounds weird~~but it really works!it really confusing me!!any wrong with the machine??need to update firmware?
            • leo34staffs
              copierman
              • Aug 2007
              • 503
              Thanks for the input guys, I did find the answer on ricohs tier 2 site, that described the fault i was getting exactly, HDDs (pair) sorted the problem.
              • sostek
                • May 2010
                • 81
                hi guys, I have the same "plesae wait " message , disconnected both HDD, still says please wait...
                any ideas?
                • leo34staffs
                  copierman
                  • Aug 2007
                  • 503
                  Not long after i had another machine doing the same thing and it turned out to be the 12v line on the psb ( i think thats all the 12v line is there for, the hdds)
                  • sostek
                    • May 2010
                    • 81
                    Turned out to be the controller. thanks for the input
