Slow respond from PCC4.
  • aaalexxx
    Engineer
    • Jul 2009
    • 51
    Hi guys,
    the users is complaining that PCC4 respond is abit slow.
    it's taking about 6-8sec to see my list of print jobs.
    any of you experience such issues in your environment?
    there's mp8001, mpc7500, mp5001 in my environment.
    appreciate your feedback.
    thanks in advance.
  • TonerMunkeh
    Professional Moron
    • 3865
    What's PCC4?
    Hit it.
    • aaalexxx
      Engineer
      • Jul 2009
      • 51
      opp.. sorry. Equitrac. =)
      • TonerMunkeh
        Professional Moron
        • 3865
        What speed does the customer's network run at? Is the machine set to auto detect the network speed? Try setting the speed down to 100mb full duplex, then 10mb full duplex. See if there's any improvement.
        Hit it.
        • cengizkurban
          PCC4 Issues
          Hi Guys,
          As I know PCC 4 has a lot of issues. Equitrac will update PCC 4.01 to 4.03. In August the version will be 4.04 or something. Try not to install this version to customer. Also there are new VM card updates.
          The issues are below;
          - Forgets card registration after sleepmode
          - Loses configuration sets after sleepmode
          - Java crashes sometime and does not starts after sleepmode
          In your case it looks like a firmware issue. Try update everything with latest updates. You'll be fine. If not Equitrac server pc has low memory or has less configuration then it should be.
          Cengiz
          • fbkhan3
            • May 2012
            • 421
            PCC4 Installation Error
            hi tech's
            Its my first time installing PCC4 with Ricoh MP 8001,Pcc log in screen is there but with server communication error at very right corner,,i need to know if i did miss something during instillation or is there something to do with EQserver?
            Second issue is if i need to upload CSV to Machine's HD how m i goin to do that?with Smart net monitor for Admin or is there any other way to do it?
            Appreciate your help!
            Regasrds
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: Slow respond from PCC4.
              Woah there fella, too many questions lol
              Right, connection problems - on the ops panel press the following sequence -
              Start 0 1 2 3 1 2 3 0
              This will take you into the Equitrac configuration. The password, unless it has been changed, should be equitrac. Check the server address. If it's a DNS hostname (i.e. server1) and the machine hasn't had the DNS / domain information input into it, the machine won't connect to the server. Try using the IP address instead. Give the machine a reboot and see if it tries to connect after that.
              With regard to the CSV, what are you trying to upload to it?
              Hit it.
              • fbkhan3
                • May 2012
                • 421
                Thanks a bunch M8..i have tried everything you mentioned,even i'm able to ping the server ip from MFP but it's still the same and seems no luck nowhere near,i have also went through following few details and it's there.
                You need to make sure you have license for Ricoh embedded. This is displayed in the licensing assignment screen in the system manager. Without this it will not work.
                2. You need to be connecting to the server running the EQDCE service, make sure that you are entering the IP address in the server settings if you are not sure that the DNS is set up correctly in the device.
                3. Go into the Equitrac setup and check the settings, you do this by entering the following keys on the MFD
                Start 0 1 2 3 1 2 3 0 and enter the password equitrac
                (once configured this password changes to 2468 (or that you have set in the embedded devices in the system manager)
                4. Lastly make sure the firewall i open between device and server on ports 4940, 2938 and 2939.
                Is there anything else to which need to look in to?
                • torsol
                  • Dec 2008
                  • 5
                  What Server OS is the installation, is the EQ componets split up or on same server, what version of PCC do you use? 4.1.0.0465 installed on SD card?
                  I assume you know the other ports, just in case:
                  • fbkhan3
                    • May 2012
                    • 421
                    Thanks a ton buddy,
                    it's win server 2008 R
                    components are on same server not split up
                    PCC version 4.1.0 installed on JAVA V.5.05 i guess
                    Ricoh MP 8001
                    guess i missed the trick during Component installation,is there a way to reinstall or recheck those components specially DCE?
                    • torsol
                      • Dec 2008
                      • 5
                      Just do a repair of the EQ installation and make sure all components are selected, also check under licensing assignment.
                      In 2008 did you check the internal firewall(or antivirus programs).
                      • fbkhan3
                        • May 2012
                        • 421
                        [QUOTE=torsol;292010]Just do a repair of the EQ installation and make sure all components are selected, also check under licensing assignment.
                        Thanks a bunch,
                        yes i did check the firewall setting,ports,did turn off kesperSky to figure it out but no luck yet,
                        could you be more specific about repairing of EQ installation option?where i would be able to see if those components are installed or not?
                        Complete Reinstall would make it work you think?
                        Appreciate your help ,
                        • ferastec
                          • Jun 2009
                          • 107
                          Hi guys, have you found a solution for this issue? As I have the same but pcc4 takes almost 40sec, the equitrac which I have installed is V5 with Pcc 4.2.1
                            • 37550
                            See the thread Equitrac PCC4 Login delay
