Scan to email
  • david ahn
    • 13
    Scan to email
    I want to use scan to email from aficio 2045e.
    When i put our firm's smtp information into the machine, i can use scan to email.
    But when i put in my gmail smtp information, the machine fails to send the file.
    I think the machine can work through the gmail smtp mail server as long as the information is correct.
    The gmail infomations that i typed in for scan to email are
    server name : smtp.gmail.com
    port number : 465 (that is gmaill smtp port number, not 25)
    and my gmail account id and password.
    Can i use scan to email via gmail smtp?
    or is there any other public smtp server for scan to email.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Is SSL enabled?
    Go User Tools-> System Settings-> Interface Settings-> Page down-> Permit SSL/TLS comm. Select "CipherText priority"
    Also, make sure the Adim's e-mail matches the Gmail account.
    • tmda2299
      • May 2008
      • 10
      Ricoh copiers do not support SSL over SMTP.
      To work around this, change the Outgoing SMTP server to smtp.googlemail.com using port 25.
      • Ricoh-ono
        • 339
        I have had to use Stunnel or Mercury mail to relay the scan to GMail's server.
        Do what you can, with what you have, where you are. ~Theodore Roosevelt
        • richardjj
          Technician - I.T Support
          • Feb 2010
          • 18
          This might help ?
          Scanning to google mail needs to be setup through aspmx.l.google.com (or IP address 74.125.53.27) no Authentication is needed
          It also requires the "Senders\Administrators email address" to be Valid
          You cannot Telnet into this server from Run or do a connection test from the Copiers Interface but it does work,
          • toddanderson
            • Dec 2005
            • 238
            Gmail with kyocera products
            Does the smtp gmail server work with any kyocera products
            I have tried smtp.gmail.com and smtp.googlemail.com and tired several ports
            to no avail
            I have tried several kyocera procucts the taskalf color and B&W
            doany of the kyocera products work with gamil ?
            • teebee1234
              • Jul 2008
              • 1670
              to no avail
              You will probably have better luck posting this question in the Kyocera forum, though someone here may have an answer.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Personally, I've about had it up to my ears in trying to get scanning to work with Gmail and Ricoh products.
                What I normally do is test with my personal "test" GMX account, and see if that works.
                If it does, I have the customer set up their own account to use with the machine. Of course, that's not a good idea if they will be doing a bunch of scanning.
                If it does not, there is a very good chance that their ISP is blocking outbound SMTP, in which case no provider will work. It seems like I've been seeing more and more of this lately; it just happened one day last week.
                When scan to email simply won't work, hopefully it's a machine that can scan to folder, or possibly FTP.
                โ€œI think you should treat good friends like a fine wine. Thatโ€™s why I keep mine locked up in the basement.โ€ - Tim Hawkins
                • msaeger
                  • Sep 2008
                  • 333
                  I have never gotten Gmail to work but like Ken said GMX will work until the decide to require SSL. I have set a few people up with GMX but I don't really like to it feels like a hack.
                  • galenwollenberg
                    Re: Scan to email gmail and stunnel
                    i spent quite literally 2 weeks trying to get stunnel to work so my canon copier would talk to gmail.
                    the problem was that i could enable SSL on the canon copier but i could not change the port. so it wouldnt talk to gmail.
                    here is my stunnel.conf for any one who is having as much trouble as i did getting stunnel and gmail to work.
                    the gmail account im sending from has pop/imap enabled in the mail settings in gmail.
                    192.168.150.2 is my internal windows server's ip running stunnel.
                    i could not get 127.0.0.1 to work as the outgoing or incoming mail server's ip in the copier.
                    i just put my stunnel server's ip in the copier as the mail server: 192.168.150.2
                    also i think i had to turn off or on smtp auth on the copier for it to work. your mileage may vary...
                    just copy paste this into your stunnel.conf for gmail.
                    cert = stunnel.pem
                    socket = l:TCP_NODELAY=1
                    socket = r:TCP_NODELAY=1
                    client = yes
                    [pop3s]
                    accept = 110
                    connect = pop.gmail.com:995
                    [imaps]
                    accept = 143
                    connect = imap.gmail.com:993
                    [ssmtp]
                    accept = 25
                    connect = smtp.gmail.com:465
                    • Dexor
                      • 223
                      Re: Scan to email
                      I've always been able to scan to email via smtp relay services. I only use it when I have to, i.e. problems with regular email settings @ the clients office. If nothing works, smtp relay (runs on port 80) always worked.
                      This time - nothing works. I have two different machines 2022 and 3245c - they both won't allow me to send email. I've configured MS Outlook with the same settings and it works perfectly fine. I've yet to check SSL/cipher priority... perhaps this will fix it.
                      My question is - dumb as it may be - does firmware on the NIC would have anything to do with scanning to email? I always upgrade NIC's firmware as with win7 it's always a problem - when scanning to folder. But scan to email?....
                      Pulling my hair here
                      • rthonpm
                        • Aug 2007
                        • 2859
                        Re: Scan to email
                        NIC firmware could affect scanning as the NIC does control communication with the various ports. In this case it sounds more like a security setting somewhere along the line that the machine can't overcome either through design or technological limitations.
                        • chaunce54
                          • Sep 2009
                          • 32
                          Re: Scan to email
                          I know that Verizon DSL blocks port 25 to any other domain but there own. To get around this, use port 587. It will work with GMX on port 587, and probably most other email servers as well.
                          • chaunce54
                            • Sep 2009
                            • 32
                            Re: Scan to email
                            I have cleared up a similar problem by going into service mode and doing a scanner memory clear. You could give it a try. It will revert all of your scan settings back to default, so don't forget to change them back if you are using non default scanner settings.
                            • techsass
                              • Dec 2010
                              • 248
                              Re: Scan to email
                              One other step I do is login to their gmail account and change the Browser Connection setting (under Mail Settings) to "Don't always use SSL".
