I decided to post this thread here because in no sub forum dedicated to this product.
I have recently received 6 or 7 units like this, all of them 6501 in my territory all of them having not even a month in field.
This one started the day with a SC 496 at 7:47 and very light image and continued in one hour with SC 360 and SC 410 and again SC 496, 410, 360.
Machine has 2 weeks in field and meter reading shows K:19507 and Color:424
Customer is boiling and they placed a rush call.
At my arrival the machine was in a very undertone condition for Black...all other colors OK.
SC 360 on the screen and any attempt to clear the code and to print SMC report failed so I was forced to clear the code, reboot, do a forced toner supply cycle for K once, do 3820 Procon Exe Density Adj...and at the end 2111. Corona unit was partially covered in toner (toward the front of the machine) sign that the unit was leaking toner. I cleaned and reassembled the unit after I vacuumed all the toner in excess. Only after this I was able to print a SMC report.
SMC reports was showing:
2263-01 TD Sn Chk Disp Vt:K 2.29
2302-01 Temp/Humid Disp: Temp 21
-02 Rel Humidity 25
-03 Abs Humidity 4.59
-04 Curent Env Disp LL (This is Calgary...very very dry)
2901-01 Disp T/H Humid Recent 27
3001-01 TD Sn: Vt Disp K: 2.51
3001-01 Vtcnt
isp/Set Current Val: K 8.60
-05 Initial Val: K 8.60
3003-01 Vtref: Disp/Set Current Val: K 2.37
3010 TD Sn:Factory Data (matching with the sticker on the K unit)
3101-01 ID Pattern: Display Applied:K 0.170
3251-01 Tnr Supply Time Sub Hopper CL:K 0 (???)
3561-01 Dev gamma
isp Actual Val: K 0.74
-07 Target Val: K 0.98
-13 Environ Corr:Bk +0.00 (???)
-19 TnrDensity Corr:Bk -0.02 (???)
-27 TnrDensity: K 7.1
3562-01 Display Vk K -14
3563-01 Dispaly Vr K -86
3571-01 Display VO K -709
3572-01 Display VdHome K -706
3573-01 Target Poten:Vd K -835
3574-01 Target Poten:VI K -600
3802-01 TD Sn Init OK? KMCY 1111
3812-01 DevSetup Exec KMCY 1111
3815-01 Dev Fill KMCY 1111
3821 -01 ProCon OK? Last 1 10101010
Last 2 - 4 56999999
Last 5 - 10 10101010
After all this I was able to recover the machine from the under toned condition but I got background and small blotches on every sheet and still the K density was not good enough.
A brand new unit and a new bag of developer brought the situation to normal....but this fix is very costly...In this case was the only solution to calm down a customer that was almost to explode....These situations start happening very often, customers are very sensitive to the machines down time...
They are paying tons of money for a top of the line color MFP that fails no longer than 20K and suddenly they have no printer, no copier, no fax or scanner so their frustration level is reaching the roof very easy.
In my case today I was able to escalate the situation and I received immediately assistance from 2 of my managers so I got a brand new unit from a not yet preflighted machine, because the D082-2214 part is not yet in the system.
It is my third experience regarding bad TD sensors...2 of them with D014 machines and this 3rd one with D081...It looks like is no improvement in between the TD sensors, they are very sensitive and are failing very easy with no chance to recover the machine.
Does anybody has a similar experience and or a fix to this problem without replacing units and devs ?
-02 Rel Humidity 25
3001-01 Vtcnt
3561-01 Dev gamma
Last 2 - 4 56999999
