Every time I try to calibrate I get a message, Test pattern could not be printed. I did forced line adjust. color registration adjust and I still get the same message. Has anyone seen this prblem?
Are all your trays set to a different thickness of paper? At least one tray has to be set to plain paper for ACC to work. Any toners low? That will stop ACC running.
Maybe try restoring factory ACC settings and see what happens, or upload the NVRAM data to an SD card and do a memory clear. (I see you're from Oakley. I used to live in Brentwood, and Antioch before that.)
