Ricoh firmware on non-Ricoh branded kit??
  • ezzysi
    • Oct 2008
    • 78
    Hi, as per the title really, am I safe to update a Gestetner badged version of a 2022 with Ricoh firmware (as Ricoh is the only firmware I have access to)
    I'm thinking the only difference i'll see is the manufacterer info change on the SP list print-outs etc?
    Anyone done it??
  • mrwho
    Major Asshole!
    • 4299
    I had that doubt before here on the forum, and I've been told by several colleagues here that the firmware is the same no matter the badge on the machine. I've also reflashed the firmware on several Nashuatec and Savin machines without any trouble.
    Mascan42
    Ibid
    • tonermonkey712
      Hi
      You should not have any problems with using firmware from Ricoh. I was using a lanier firmware file for the 1045 years ago and that was supplied to me from Ricoh.
      • Jomama46
        • 2900
        The firmware is the same. And the name on the SMC sheets is a reflection of an SP mode setting 5907, I think. Called Plug and Play name.
        sigpic
        A+; Network +; PDI+
        • ezzysi
          • Oct 2008
          • 78
          Thanks for the replys guys,
          firmware is now updated and working perfectly.
          Si
