I have two machines for rebuilding with same problem: op. panel dont work and can not be calibrated, all other mechanical buttons works fine. Any suggestions?
Aficio 3045 dead lcd panel
Tags: 045, 104, 1045, 2045, 304, 3045, adhesive, aficio, business, calibrated, control panel, dead, fine, lcd, mechanical, models, panel, panels, rebuilding, replace, screen, touch, touch screen, work
On earlier types 1045 and 2045 never had that problem, is it some problem only with these machines ?Comment
Modded touch screen is H310 9900.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Make sure the top cover of the control panel is not contacting the touchscreen or some foreign matter between it and the screen. Run a business card or something thin like that all the way around under the lip of the cover and above the screen. I've seen crumbs do this and also the top cover overtightened. This will prevent any operation of the panel.Comment
