Savin C3828 - No Toner: Magenta
  • listsubscriber
    • Aug 2008
    • 83
    We have replaced the Magenta twice in this machine and it still gives us the same error. Wanted to check here before we started randomly replacing parts on the machine. We have tried with a 3rd party toner and now a Ricoh toner but we get the same problem. You guys ever run into this issue?
  • Vulkor
    • Jun 2009
    • 946
    When Toner Pumps fail or they or the lines get clogged. yep
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      Your aftermarket toner may be the culprit of the clogging. I haven't had any good things to say about any aftermarket color toner on these machines. I've had several clog machines, repeatedly. I'm not a fan. Replacement of pumps and tubes followed by ditching of the aftermarket toner would be my course of action
      • listsubscriber
        • Aug 2008
        • 83
        Thanks for the reply. A thorough cleaning seems to have cleared it up. There was magenta toner all over the inside of the machine. I did see that the hole allowing the toner to come in was backed up pretty bad. Vacuumed it out and cleaned up the dev unit real good. All seems to be fine for now. Thanks again.
        • tinfox
          • 317
          I had that happen with magenta on a machine with under 10K. I'm not sure what happened but while I was replacing the magenta dev they asked me why it was so hard to get the magenta cartridge in. ?!?!?
          This was on a 32 series tho.
