SR790 jam .....
  • mapsanji
    • 12
    SR790 jam .....
    Hi all...
    Need some help on mpc3000 with sr790 finisher.......
    I have this awsome problem whith finisher - jam continuously only on top output tray as paper( A4 ) comes out halfway it just stops, same with A3 size BUT A5 is working fine, changed output tray to shifttray all works good no problems. Swop finisher with another one and it to do the same problem, I did firmware with no luck I also make sure on paper size settings is correct. Anyone had that before??
    Thanx for feedback...
    Martin
  • TonerMunkeh
    Professional Moron
    • 3873
    What sort of machine is it attached to?
    Hit it.
    • mapsanji
      • 12
      Ricoh MPC3000.....
      • mapsanji
        • 12
        Ricoh MPC3000...
        • collme
          Ricoh tech
          • 221
          what jam codes are logged in the smc logging data report?
          • Copierguy123
            Hey I had a similar issue and it turn out to be the shift tray lift motor, the problem starts with the jams and as the motor gets worse you will get error codes. the tray doesn't go up and down and that's why it jams.
            Check that
            • mapsanji
              • 12
              Hi "Copierguy" thanx for this info but its not that.....shif tray work fine, I swoped the finisher with another finisher and still the same. To "Callme" the jam codes is as follows: plotterjam hist = 100 P/jam location ="Finisher entrance" = 104 thats it !!
              Hope that helps !!
              Thanx
              • TonerMunkeh
                Professional Moron
                • 3873
                Okay, let's go through this. You've said you've swapped the finisher and it's still doing it. That leaves only a couple of things it could be. Firmware, duff finisher connector on the machine, harness connecting finisher connector to BICU and BICU itself.
                Update ALL the firmware to latest levels, absolutely everything including the finisher and try again. After that it's board time.
                Unless that is - you've two finishers with defective entrance sensors, broken junction gates or missing / disconnected springs!
                Hit it.
                • collme
                  Ricoh tech
                  • 221
                  jam 104 is actually
                  Finisher Drive Motor
                  (B408)
                  Exit guide plate HP sensor does not turn
                  on or off for specified time.
                  jam 103
                  Lower tray exit sensor does not
                  detect paper after the stack feed-out
                  belt has fed paper.
                  Lower tray exit sensor still detects
                  paper after the stack feed-out belt
                  has returned to the home position
                  jam 102
                  Finisher Staple (B408)
                  Paper does not reach to the staple tray
                  entrance sensor or stay at the staple tray
                  entrance sensor.
                  jam 101
                  Finisher Shift Tray Exit
                  (B408)
                  Paper does not reach to the lower tray
                  exit sensor or stay at the lower tray exit
                  sensor.
                  jam 100
                  Finisher Entrance
                  (B408)
                  Paper does not reach to the entrance
                  sensor or stay at the entrance sensor.
                  so if your jam is 104 then it is not finisher entrance.
                  pasted out of mpc3000 service manual for you
                  • spaceman99
                    • Jul 2009
                    • 174
                    i had a mad fault like this and it turned out to be the door sns in the bridge unit. It thinks the door opens and happens so fast it does not appear as a fault code or on display.
                    If not then i would go for IO pcb .
                    good luck
                    • mapsanji
                      • 12
                      Got it working............
                      Thanx Spaceman for that info it turn out to be one of the door switcheson the bridge unit, weird fualt but its working.....
                      Cheers
                      • spaceman99
                        • Jul 2009
                        • 174
                        nice 1
                        NO WORRIES......Happy to help....
