Ricoh MFP - Hard Disk Setup Software for PC
  • Martin Capehart
    • Aug 2025
    We are looking for software that will allow us to buy the same hard disks, that Ricoh sells us at 500% markup, so we can partition and format them ourselves. Thanks!
  • Canadian Tech
    Too Long in this field
    • 32
    Standard PC hard drives will work, just format them on the MFP.
    Most of the time the operators need fixing, not the machine !!!
    • miro
      • Feb 2010
      • 87
      If you need to replace existing hard disk, you can put any type and any size of hard disk.
      Just format hard disk with function in service program mode on MFP.
      Only on canon mashines is problem with types of HD and partitions.
