anyone have the part number for the print scan poscript dimm for slot 2. thanks t
af-1060 postscript dimm
I saw that part in the manual, but I'm pretty sure that's not it. A parts check shows that as "Dimm Board Facsimile $150.69". The install docs also shows it going into a vertical slot as opposed to the ps dimm laying flush above the printer/scanner dimm. To be even more confusing they mix together the B064/065 with the B140 series (which uses an SD card). The PS is licensed and most likely costs well over a $1,000.Comment
