lanier 2851 finiher errors
  • tommygun
    • May 2010
    • 21
    i have a brand new 2851, which i have run up and got working but when i put the finisher on, it says that it has a 798 error, i cant find that error anywhere, and dont know what to do. any help would be much appreciated thanks.
  • totoro
    • 568
    Is this the same as the Ricoh 2851? Do you have the service manual? There is a whole slew of 798 codes; is there a sub code to the 798?
    Totoro
    • tommygun
      • May 2010
      • 21
      yeah it is the same, i got a service manual but the only error code i can find is 792, the code on the screen just says '798 finisher error'
      • totoro
        • 568
        In my service manual on page 3-30 SM appendix it says
        798 Finisher unit error, level B
        The machine cannot communicate with the bridge unit,but not the finisher. I assume the cannot means can.
        possible causes:
        poor connection between finisher and mainframe
        finisher harness damaged or defective
        finisher unit defective
        What does SP 7403 have logged?
        Totoro
        • tommygun
          • May 2010
          • 21
          fixed it, it was actually the upper tray level switch was in the wrong position, thanks for the help
