What can you say about the Aficio 2035/45
  • Joel
    • May 2010
    • 46
    Gud day Technical People and End users,
    im quiote new with this type of machine and i want to know the Aficio 2035/45. are they a good buy?
    what are the frequent problems of this machines?
    are they easy to be maintained?
    please give me some honest feedback on this.
    Thanks a lot for replying in this thread.
    God bless.
  • zed255
    How'd ya manage that?
    • 1024
    I'm not fond of that entire series of engine. I suppose they run OK if you have someone who is thorough with maintenance and uses OEM parts (and do use OEM toner). Issues with these, there have been a few. My personal gripe list:
    Run dirty, don't push the PM interval, regular thorough PM's are a must. No skimping on parts!
    Seem to record more jams than other engines, helps to replace clutches and rollers regularly
    Fuser cold roller builds up quickly and can even get a paper wrapped around it. They are aluminum and not as easy to clean as the steel ones used in other models.
    The toner hoppers often leak and the 'paddles' inside come off
    Cushions in interchange unit go gooey and have to be removed, a PITA
    Did I mention they run dirty?
    Anyhow, good luck. This is one engine I wish Ricoh had have realized was a turd after the abysmal Aficio 350/450. It did improve and the Aficio 2035/2045 and 3035/3045 are likely the pinnacle of it's evolution. The MP3500/MP4500 used a 'new' toner and were a step, nay, giant leap backwards IMHO.
    • Vulkor
      • Jun 2009
      • 946
      I think Zed has pretty much hit it right on the head.
      • TonerMunkeh
        Professional Moron
        • 3865
        One thing I'll add - change the toner seals on the dev unit and PCU every pm (I do them every dev / drum change) - give it a bloody good vac out too. It'll thank you for it.
        Hit it.
        • Joel
          • May 2010
          • 46
          are you saying that this machine is quite good in some aspect? just always clean this machin and follow its scheduled PMs?
          • rthonpm
            • Aug 2007
            • 2859
            As you'll be getting these as second hand machines if you're looking to buy them, if they have been properly serviced they can be fairly reliable. They do run very dirty though as everyone has said and do need quite a bit of work to keep clean and properly running but they can be a good machine if all you want is a copier. You're better off trying to get the 3035/3045 model among the older models as they are much more reliable in terms of fusing and copy quality. The MFP functions on the 2035 are fairly limited, especially scanning, so a later version machine is always a better choice if you need these functions.
            • Joel
              • May 2010
              • 46
              someone offered me this machine coz im looking for a 35 to 35 copies per min copier. so are there any brand that would you say good enough for this machine?
              thank you for the advises
              • iMind
                Vacuum Cleaning Expert
                • Mar 2008
                • 1116
                Joel Joel, this is not a sales department and in this forum there is nothing better than a Ricoh, so just bye it or leave it... or try a Gestener, Savin, Nashuatec, Rex Rotary, or a Lanier, hehehe
                • PA5RR
                  • Aug 2009
                  • 62
                  I service these models for some years now, My advise : do NOT buy these machines used.......I would suggest you look for aficio 1022 / 1027 / 1032 or the newer model 2022 / 2027 / 2032
                  the 2032 model is the fastest ...32 sheets a minute These are very userfriendly and supplies are not to expensive... difference 1032 and 2032 series is the newer series can do scan to mail the older series does not.
                  technicians are the only ones that don't trust technical stuff !
