Aficio 450 SC302
  • hknwbec
    • 214
    Aficio 450 SC302
    After cleaning developer unit and then after printing 8 copies will come brack copy ,What is the problem on drum unit or on the developer unit. could you guide me how to solve the problem. Thanks !
  • Eric1968
    • 2458
    SC302 has something to do with the charge roller (charge roller current leak detected). Check the charge roller connections and make sure the charge roller is clean (or replace it).
    • Joel
      • May 2010
      • 46
      yes i aggree with Eric1968 and check also the PCU grounding.
      • hknwbec
        • 214
        Thanks for your informations , Now is Ok,
