256MB SDRAM chip in Ricoh 2022/Lanier LD122?
  • sylerner
    • Jul 2025
    Does anyone know if a Ricoh 2022/Lanier LD122 can accept a 256MB SDRAM chip instead of the specified 128MB chip?
    If so, does the copier take advantage of the extra memory?
  • zyqwiz
    • Jun 2009
    • 333
    If the memory does work it would be fixed at 128MB - same as the HDDs are fixed at their specified useage no matter how big the drive is.
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      Yes it will accept a 256 Mb RAM, "if the RAM where not to be acceptable, the machine should give a SC819"
      • sylerner
        Sorry for being a bit dense, but are you saying that you know that a 256MB module will work, or are you saying to try it and see if I get a SC819?
        • iMind
          • Mar 2008
          • 1116
          Yes 256Mb RAM will work its the max. upgrade possible.
