Ricoh Aficio SP C410 dn - problem with resetting
  • zomowiec
    • May 2025
    [Error Code] Ricoh Aficio SP C410 dn - problem with resetting
    over night i got error code sc545. I found out that the fusser might be bad, so i ordered a maintenance kit replaced all the components in the kit but after powering on the error code is still there. I searched a lot of sites for how to get rid of it, people say to go into service mode and turn off the printer and back on, but this printer has no key pad so all the direction how to get to the service mode were press and hold # key and enter 107 code or something similar.
    I only have four arrows, online menu, job reset, ok, escape and three buttons under the lcd display.
    Please help me reset this code.
    Thank You
  • zed255
    How'd ya manage that?
    • 1024
    On the printers you hold down the UP and DOWN arrows for at least five seconds, release and press ENTER quickly.
    Use the arrows to select #2 Engine SP and ENTER.
    Arrows again to select #5 Modes and ENTER.
    Arrows again until #810 SC Reset and ENTER. Check the display, you will likely have to hit ENTER again to execute the reset. It should indicate the reset is complete.
    Power OFF and ON.
    If there are no further issues it should be functional again. There is a second method to enter SP mode but it eludes me at the moment.
    • lonesome
      Got the same error on a 610N a while back, to the best of my recollection, this is what I did:
      Turn the printer off, press online and scape (hold them) turn the printer on and wait 15 secs or until the service menu comes out.
      Release then go to Engine Maintenance
      Enter
      Search for SP5810 enter
      Accept change then turn off the printer
      Test.
      If this doesn't work, get away from the printer before you hammer it out
      • zomowiec
        Thanks guys for the reply the up and down arrow for couple of sec worked for me thank you guys again
