MP1600 SP - Printing
  • hmac
    • Aug 2009
    • 129
    Hello
    I have a MP1600SP who can not print.
    I can scan and I have access to the web interface.
    I test my driver settings with another MP1600SP, it works.
    Is there a dedicated card just for printing, because i can scan ?
    Thank you
    _________________
    HMac.
    _________________
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Did you try the RPCS driver?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Vulkor
      • Jun 2009
      • 946
      Good Suggestion in case machine didn't come with PCL support.
      Also does the PRINT Button on the MFP work? I've seen Print Firmware get messed up and scanning still worked but printing didn't and the print button just beeped when pressed.
