MP171SPF network printing issue
  • ferastec
    • Jun 2009
    • 107
    Hi,
    Then I have changed the control board with brand new one, and the address book issue been solved, and we can scan and logged as admin.
    But network printing is not happening!!, USB printing is fine. We can scan as I said and we can access the WIM.
    Can you advice please.
    Regards
  • Vulkor
    • Jun 2009
    • 946
    Try reloading the Firmware. You say you can USB Print, and I'm assuming you are Network Scanning?? Pretty sure this model doesn't scan via usb.
    • Vulkor
      • Jun 2009
      • 946
      Can't see them needing to change an SP if they can access the Web Image Monitor.
      • Vulkor
        • Jun 2009
        • 946
        Meh no prob. Waiting for him to reply.
        • ferastec
          • Jun 2009
          • 107
          hi guys, sorry i could not reply on time as i was in out station, the Firmware been already updated, at the time of installing the new contrl board.
          • oswaldo160
            • Oct 2008
            • 69
            I had this trouble.
            I only restarted the NIC in the sp 5....
            first put in 0
            after turn off and on the machine
            and change to 1.
            • PinevskiS
              • Jul 2009
              • 283
              Originally posted by ferastec
              Hi,
              Regards
              Hi,
              I have this problem every day.This machine have problem whit SD Card.Go to SP Mode
              ( 5846-50) and reset address book. If the problem remain you must change SD Card.
              I don't know why only MP 171 spf have this problem with addrss book error. When I instal new machine , other day customer call me and say machine call address book error.Ricoh say format HDD or change Printer Controller.
              • PA5RR
                • Aug 2009
                • 62
                The problem most of the times with this new model : ram memory module on controllerboard...... I had a few now with the same problem, and most were solved with new memory module.
                In one case it was the controllerboard.
                Please tell us all what your solution was , so we all learn !!
                technicians are the only ones that don't trust technical stuff !
                • huberto233
                  • Nov 2008
                  • 40
                  If you print out the Configuration page from the Printer Settings menu it shows the IP address that was entered. Also on some models MP171SPF there is no mention of IEEE802.1x on this page. However if you print out the configuration pages from System Setting - Interface Settings - Network it shows the IP address as 11.22.33.44 and 1/4 of the way down on page 1 you will see:
                  IEEE802.1x Settings
                  Ethernet:On
                  It should be:
                  IEEE802.1x Settings
                  Ethernet:Off
                  To change it go to Interface Settings – Network and look for IEEE802.1x or wireless settings and make sure they are off or inactive.
                  Network+,
                  • PA5RR
                    • Aug 2009
                    • 62
                    IEEE802.1x Settings
                    Ethernet:On
                    It should be:
                    IEEE802.1x Settings
                    Ethernet:Off
                    (QUOTE) Then I have changed the control board with brand new one, and the address book issue been solved, and we can scan and logged as admin.
                    But network printing is not happening!!, USB printing is fine. We can scan as I said and we can access the WIM. ( UNQOUTE )
                    Why don't you read the whole thread? No offence but your remark has already been discussed.....
                    • huberto233
                      • Nov 2008
                      • 40
                      I am assuming that the different printer drivers and ports including lpr have been tried ?.
                      i would also try to print the config page 5990 007 and see whether any sort of access range has not been set up.
                      Network+,
                      • ferastec
                        • Jun 2009
                        • 107
                        yes guys i am still working with this issue, i will update all of you if i get the solution
                        • pppp
                          Technical specialist
                          • Sep 2010
                          • 43
                          MP171SPF and address book error
                          Dear All,
                          We have got 26 pieces of MP171SPF machines with address book error. The only way to resolve problem is repacing gw controller board.
                          I know that a lot of technicians in Europe met that issue. We need more reports from Europe regarding address book error in MP171SPF machines.
                          Regards
                          pppp
                          The text is temporary deleted in part because of politics. I have to describe the issue more "politically".
                          Final text soon.
                          Microsh.t is finished and Linux Rulez
                          • francisco
                            • Nov 2009
                            • 168
                            adress book error
                            Originally posted by pppp
                            Dear All,
                            Regards
                            pppp
                            Final text soon.
                            in this model the adress book data is in flash ROM,not the same of previous model MP161 was in SDcard.
                            you can check it in SP5-846-43
                            1-sd slot 1 (MP161)
                            2-sd slot 2
                            4-flash ROM (MP171)
                            20-HDD
                            in most of cases just turn off and on resolves,but if not you must change the controller
                            • pppp
                              • Sep 2010
                              • 43
                              Hi,
                              The problem is that the address book error dissapears after rebooting .... at the beginning.
                              AT the end there is no solution. The machine is locked, there is no possibility to log in via web and the only one solution is to replace board.
                              We found addres book error depends on frequency of book usage. Every machine is working all the time - no power off.
                              Is it possible to move book from flash to sd card or hdd?. Shall we say we have additional card inserted or hdd.
                              pppp
