Ricoh FT-3713
  • tcypy1961
    • 773
    Ricoh FT-3713
    I was called out to one of these copiers with the knowledge that the machine had an E29 error code. It had the error code but when I moved the scanner unit I got an E22 error code. I was wondering if there are any common causes for these error codes? Any help appreciated, thank you.
  • Eric1968
    • 2458
    E22 means 1st Scanner Home Positioning Error. E29 means Lens Home Positioning Error. I think you have to check the home positioning sensors or adjust the 1st scanner and lens assembly. And advise the customer to take this machine to the nearest museum!
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      E 29 lens home position E 22 scanner home position
