Ricoh PCL Default Editor
  • is99
    • May 2010
    • 10
    I want to be able to restrit user to Locked Jobs only. I can do it using Ricoh PCL Default Editor.
    The problem is that I also want to install on the server two drivers one for BW and another for Color that will print to the same machine.
    I can create two different customized drivers one with Locked Prints and Color and another with Locked Prints and BW, but the problem is that when I try to install the second driver Windows say that the driver is already exists and if I want to replace it.
    So basicly Windows "thinks" that both drivers are the same, how is it possibe to install both of them? I mean how to make Windows think that the second driver is totally different one?
    Thanks.
  • Vulkor
    • Jun 2009
    • 946
    Tell it don't replace it. And at it should say Ricoh model# copy 1 or something as the name and you have to rename it.
