Problem with MPc2500
  • kassa
    • Oct 2008
    • 79
    Good morning to all,
    I have a problem printing a color image into a .doc file on a MP C2500 as you can see in the attached file:
    http://img143.imageshack.us/img143/4...3657000013.jpg
    When I print the same image in B/W I have no problem. Printing other color images there is no problem.
    I printed the same image with a MP C2800 and the result was ok either in color or B/W.
    Thanks for your help.
    Best regards
  • brodera
    • Aug 2009
    • 106
    I have seen this before. The one thing that i did was to open the CYAN DV-box *in your case*, and sort of like used a credit card to chop lumps and remove dust.
    In some cases it works, but if it dont, you prolly need to change the DV or the whole DV-Box.
    Im not 100% that i can be the DV, but you can always try.
    Best Regards
    • Smee
      • Aug 2009
      • 178
      yeah, do sky shots of each colour - yellow, magenta, and cyan - to work out with dev unit has the deletion lines then vac out the dev and replace it.
      • kassa
        • Oct 2008
        • 79
        • gregoriojc
          • Aug 2008
          • 56
          check your printer driver try to use pcl5 or pcl6 sometimes having problem on Rpcs driver depending on the OS
          of the computer.
          goodluckgregoriojc
