Ricoh 1515F
  • Jomama46
    • 2900
    Ricoh 1515F
    A tech just called me on this one. When he presses the FAX button, it double beeps instead of going into fax mode. Recycling the power didn't help. I told him to access the battery board on the FCU and press that in good because I have seen that on new units.
    I haven't heard back yet but has anyone else seen that?
    Copying works fine.
    sigpic
    A+; Network +; PDI+
  • mikadonovan
    • May 2008
    • 2931
    If your fix doesn't work, could be a bad FCU, or it needs initialized.
    NEVER ASSUME ANYTHING
    • Jomama46
      • 2900
      The quick fix didn't work and neither did initializing the RAM so I gave him a price on the FCU. He is pondering it. Thanks for the reply
      sigpic
      A+; Network +; PDI+
      • Vulkor
        • Jun 2009
        • 946
        Had this happen with Printer option before. It double beeped and never loaded. It was the FIRMWARE. Reloaded and all was well.
        • Jomama46
          • 2900
          Hmm, Maybe I'll try that first. thanks
          sigpic
          A+; Network +; PDI+
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Before you too far, be sure that the fax didn't get set up to use IP or Internet fax; it needs to be a plain ol' analog phone line.
            I had a tech accidentally set this a few months ago. The machine is looking for a connection that doesn't exist. (That was on an MP171, but it's basically the same machine.)
            • Jomama46
              • 2900
              No, its been working as a fax for a year or so
              sigpic
              A+; Network +; PDI+
              • Vulkor
                • Jun 2009
                • 946
                Wouldn't Fax Redlight and have an SC?
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  You'd think so, but no.
                  That's what threw me off for an hour or so before i found it.
