scanroute V. lite
  • DINGO
    • 661
    scanroute V. lite
    Hi
    Can somebody help me, where i can found the scanroute V.2 lite?
    thanks in advance
  • Steve G
    • Mar 2010
    • 15
    Follow the link...
    It's a 20MB download & set up ok for me...
    Downloads
    • DINGO
      • 661
      Thanks friend,
      and the purpose, do you now if there any version freeware of the scanrout that works in w7.
      i apreciate very much your help
      mi best regards
      • zed255
        How'd ya manage that?
        • 1024
        ScanRouter is officially no longer supported or receiving any further development. I don't believe it is compatible with Vista or Windows7. You may want to run an XP or Win2K VM for the purpose of running ScanRouter.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Zed is correct; SR won't work with Vista or Windows 7.
          If adding another PC with XP or 2000 isn't feasible, you may be able to add a Virtual Machine session to a Windows 7 box.
          • DINGO
            • 661
            thanks
            Thanks very much for yours replys, good idea "virtual machine"
            regards
            • DINGO
              • 661
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Make sure that you open port 3670 (both TCP and UDP) on the server, even if the firewall is turned off.
                (Seems silly, I know...)
                I've had to do this more often than not to get it working.
                • DINGO
                  • 661
                  RE
                  Thanks KenB
                  tomorrow i go check it.
                  • sandmanmac
                    • 3981
                    Originally posted by DINGO
                    Thanks friend,
                    mi best regards
                    Scanrouter V2 lite works with windows 7 and/or Vista if you disable user account control, restart the PC, and then manually start the service in the V2 admin utility. i've set it up several times
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Good to know, thanks for the info.
                      While it would allow Scan Router to work, though, it seems to me that most IT admins would really hesitate to lower security that much. I know that I wouldn't allow it if it was my network.
                      Of course, it depends on how your customer's IT person feels about it.
                      Again, keep in mind that the product hasn't been supported by Ricoh in 3 1/2 years, so if something bad happens they can't be held responsible.
                      • DINGO
                        • 661
                        • DINGO
                          • 661
                          • Vulkor
                            • Jun 2009
                            • 946
                            Most of my customers that use Scanrouter which is VERY FEW nowadays know to stick with the XP Box it runs on. Those that didn't we converted to scan to email. Really shouldn't be too many people needing to run Scanrouter. I think almost every machine since 2003 has SMB or Email scanning.
                            • DINGO
                              • 661
