Ok, I've searched for some other solutions and found a few sites that may hold some small key to your problem (many people are having issues with Windows7 SMB across various platforms).
Tutorial on BizHub setup (one thing I noted was that the poster states to use all CAPS for the hostname).
WDTV Forum This one suggests that you edit the registry to turn off smb2&3 and only run smb1. This is more related to smb file sharing, not specifically scanning.
Microsoft Social Forum This thread specifically addresses a Ricoh MFP and has some fairly technical advice with links to other threads with even more technical advice.
