AF 2035e issue
  • cbr600
    • Jun 2010
    • 71
    AF 2035e issue
    the copier have 700.000 prints, and the problem is i have an SC326 wich is sort of laser thing, i change the LD unit last year when i had the same SC and now is same could be anything else ? Could laser live only 1 year ?
  • tcs04
    FORMER Techie
    • 1183
    If the machine is blowing toner due to a poor seal between the dev unit and PCU the laser board may only last one week!! Change the foam seal and lock the units together!
    • cbr600
      • Jun 2010
      • 71
      ty for the point, but i allready change it couple of mounths ago when i install new dev and pcu.
      • tcs04
        FORMER Techie
        • 1183
        Is there a lot of toner leaking near the pcu / dev unit / toner hopper?
        • neergish
          • 177
          Try replacing the front door switches. When these begin to fail they can give you laser faults.
          "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
          • cbr600
            • Jun 2010
            • 71
            I solve the problem it was the sync board, the little one in the back of ld case.Ty for ur points guys.
