X-Ref Tool (Model Cross Reference)
  • Mdkoh
    • Jun 2007
    • 29
    Got a question about the Cross Reference Tool. Seems like over the last year or so the data pack has not changed. Are they updating this tool anymore or did they just drop it. The update web site is still there but everytime I download the new definitions it's the same version. Anyone got an answer?
  • teebee1234
    • 1670
    I haven't used the static version in awhile. They have a mobile version you can put on your smartphone...I set up a web link icon on my blackberry to quickly access it...
    http://www.tsrc.ricoh-usa.com/m/
    • JustManuals
      • Jan 2006
      • 9838
      That's fine for Ricoh, but for other manufacturers, I use the Katun Site at: Katun Corporation - World Wide Equivalency Lists Which covers Copiers-Printers-Fax and Duplicators.
      HtH
      Paul@justmanuals.com
      • mwalpole
        • Feb 2005
        • 17
        Cross Reference
        Here is a treat for you Copytechnet Members. A multi-vendor, multi-category cross reference for all of the models and supplies you are looking for. For Copytechnet Members only. This database covers copiers, printers, fax machines, duplicators and much more. It has all OEM and Compatible Toner, Drums, Developers, Staples, Maintenance Kits, Fusers, plus a whole lot more.
        Try the cross reference for Imaging devices, just click on the log-on tab for Answerco extensive database on the top left and use the following log-in information.
        UserID: copytechnet
        PW: answerco
        The log-on and password will change the first of each month.
        By the way "Mdkoh", this database is always being updated.
        • Jomama46
          • 2900
          I see the reference for part numbers but the model xref doesn't cross the different manufacturers. i.e. Lanier to Ricoh, Gestetner to Ricoh, etc.
          sigpic
          A+; Network +; PDI+
          • mwalpole
            • Feb 2005
            • 17
            Once you find a toner. Click on the top right and do a "Veiw All Models", this will most likely get you the all the machines that take a specific toner. A Good example, (We will be adding this data) is all of these machines take the same supplies.
            RICOH AFICIO SPC430DN
            RICOH AFICIO SPC431DN
            LANIER LP137CN
            LANIER LP142CN
            SAVIN CLP 37 DN
            SAVIN CLP 42 DN
            And here are the Black Toner Part numbers
            SPC430DN TONER, BLACK 821070, TYPE SPC430A,BLACK
            SPC430DN TONER, BLACK 821082, TYPE SPC430B, BLACK
            SPC430DN TONER, BLACK 821086, TYPE LP137CA, BLACK
            SPC430DN TONER, BLACK 821078, TYPE CLP37A, BLACK
            Lanier, Gestetner, Ricoh Cross Reference
            • Jomama46
              • 2900
              What is the seven day free trial about?
              sigpic
              A+; Network +; PDI+
              • mwalpole
                • Feb 2005
                • 17
                That is for Dealers outside of the Copytechnet Forum to try our cross reference service for Imaging devices. For the Copytechnet members I will be giving you an open invitation to use our service with a UserID and Password noted above. The UserID and PW will change each month.
                • CSI
                  • 73
                  Thank you
                  • mwalpole
                    • Feb 2005
                    • 17
                    No Problem - Any feedback would be appreciated -
                    • mwalpole
                      • Feb 2005
                      • 17
                      Password changed today - location of the log-on and password for the cross reference.
                      • Vulkor
                        • Jun 2009
                        • 946
                        Thanks, this may be of some use to me and the office techs.
                        • JustManuals
                          • Jan 2006
                          • 9838
                          the password doesn't work
                          • Jomama46
                            • 2900
                            Right, the pw changed to what?
                            sigpic
                            A+; Network +; PDI+
                            • mwalpole
                              • Feb 2005
                              • 17
                              UserID: copytechnet
                              PW: answerco
                              For August 2010 log-on info use the following for a complete copier toner cross reference:
                              UserID: copytechnet
                              PW: myanswerco
                              Log-on will change the first of each month. Feedback will be appreciated.
