SPC820DN A3 Double Count
  • NACHO459
    • Jul 2025
    Stupid Question
    To switch A3 Doublle count on, on a SPC820DN is SP5104. There is no such SP in normal SP login. So it must be in Special Service Program. How do you enter the SSP?
  • djdan73
    • Oct 2008
    • 64
    i believe when you get into the sp screen before you select a option of which button to select press and hold either the enter button or the stop button while you select the copy sp button on the screen hope that helps
    • oswaldo160
      • Oct 2008
      • 69
      Presh and hold: "up" and "down" after press "enter"
      • NACHO459
        thank you very much
        but none of the methods worked.
        There are other suggestions?
        • oswaldo160
          • Oct 2008
          • 69
          To enter SP
          1. Push the up arrow key and down key together for 5 seconds or more.
          2. Push the enter key. The message “SYSTEM ver X.XX” is shown (where X.XX
          is the firmware version).
          Originally posted by NACHO459
          thank you very much
          • NACHO459
            Originally posted by oswaldo160
            To enter SP
            Yes
            this is the method to enter SP
            I need to enter special service program
            • oswaldo160
              • Oct 2008
              • 69
              yes.
              Then you have: service, engine and end
              You chose engine
              after you search sp 5 and after the 104
              Yes
              • tekcopyer
                • Nov 2009
                • 35
                Hi,
                After you login to SP mode press hold the # sign then press the copysp. godd luck
                Everybody wants to go to heaven, but nobody wants to die.
                • Voltage
                  • Jul 2008
                  • 282
                  Maybe if you go into the SP modes the other way the option will be there:
                  If the printer is "OFF":
                  1. Press and hold down [Online] and [Escape], and then switch the printer on.
                  2. Release the buttons when you see “1. Service” in the LCD.
                  • zyqwiz
                    • Jun 2009
                    • 333
                    Service mode (CA 107 C)
                    Hold Up & DOWN arrow keys for 5 seconds, release, then press ENTER
                    Special SP (CA 107 C hold # and copy SP)
                    Hold Up & DOWN arrow keys for 5 seconds, release, then press ESCAPE for 5 seconds, release
                    Factory mode (CA 143 C hold C)
                    Power off holding down JOB RESET & DOWN arrow together then power on whilst still holding the keys down
                    • Fearless V K
                      • 620
                      turn machine off press Job Reset and down arrow then turn on
                      Don't take that toner with me!
                      • NACHO459
                        It really work!
                        Thank You so much!
