2510 in a loop
  • Rick
    • Mar 2007
    • 277
    2510 in a loop
    Help I was trying to set user codes and I enabled a setting and it wont let me do any thing . I can login as
    supervisor with password as a password but when I try do do any thing else it says I dont have authority
    for this function and when I go to user tools it also says I dont have authority for this function. Is there a memory clear setting which resets these control settings to factory default . Help this is urgent .
  • Jomama46
    • 2900
    The only thing you can do as "supervisor" is to reset the admin un and password. (admin and no password)
    sigpic
    A+; Network +; PDI+
    • rthonpm
      • Aug 2007
      • 2859
      You probably didn't set permissions for the user code, or you changed the administrator code instead of the user code. Once you enter a user code in the address book you need to enter all of the functions the code lets you control.
      Since User Tools also don't work, it sounds like the administrator code has been changed. Try logging in as supervisor and creating a new administrator account with full permissions.
      • Rick
        • Mar 2007
        • 277
        How would I do this ? Ihave tried everything and it keeps telling me no authorization for this function
        • Rick
          • Mar 2007
          • 277
          I tried this and it still wont give me authorization. is there a reset in memory clear section ?
          • Jomama46
            • 2900
            are you using WIM on the control panel?
            You dont want to Reset the RAM,that will be digger the hole deeper.
            sigpic
            A+; Network +; PDI+
            • Rick
              • Mar 2007
              • 277
              I am just using the control panel on the copier.
              • Jomama46
                • 2900
                Unless someone has changed it, it is "supervisor" with NO password. Log in with that, go to system settings then Program Administrator Mgt. Change administrator 1 to admin and no password
                sigpic
                A+; Network +; PDI+
                • Rick
                  • Mar 2007
                  • 277
                  OK I tried that and its ok now thanks
