how connect an aficio c5560 to network
  • tux2010
    • Jul 2025
    Hi,
    We didn't buy the network module for the aficio c5560 because it was optional. But now, we would like to put it on the network. So where can I buy a printer controller type 3260 for our c5560?
    Can you help me?
    Thanks.
  • Vulkor
    • Jun 2009
    • 946
    Call local Ricoh/Savin/Lanier/Gestetner copier dealer or repair guys and see what they want to install the Scanner Printer Kit Type 3260,Manufacturer Part Number: 002449MIU, You are looking at a few thousand dollars. Someone on this forum was also selling this unit http://www.copytechnet.com/forums/sa...coh-stuff.html Also when this is installed a FIRMWARE Upgrade will probably be necessary to catch your machine up to the newer or older firmware that Kit will have. So suggest you get someone to install it and upgrade your firmware.
