Ricoh Aficio 350
  • tcypy1961
    • 773
    Ricoh Aficio 350
    Customer doesn't like that they can't come up and make a copy after the copier goes down into sleep mode after two hours of non-use. I can up the time to 240 minutes before it goes into sleep mode but was wondering if there is a way to turn off the sleep mode timer and if so will it effect the copier in any way with it staying on all the time? Any help appreiated, thank you.
  • mikadonovan
    • May 2008
    • 2936
    I have looked before, but I don't believe it's possible to disable it on an Energy Star machine.
    NEVER ASSUME ANYTHING
    • jonhiker
      • 661
      Ditto. you can set it to the max of 240, but cannot disable.
      • tcs04
        FORMER Techie
        • 1183
        Try setting to ZERO, on some Ricoh machines this will turn the sleep mode off, can't remember if this is one of them.
        • teebee1234
          • Jul 2008
          • 1670
          I'm pretty sure you can disable it this way...
          user tools, system settings, key op tools, AOF to off
          • tcs04
            FORMER Techie
            • 1183
            I think the AF350 was pre "AOF"
            • teebee1234
              • Jul 2008
              • 1670
              You're probably correct, I can't remember the last time I saw one of these particular models.
              • tcs04
                FORMER Techie
                • 1183
                SP 5-305, Change from "0" To "1" This will let you set the timers in user tools to "0" which turns them off.
                • GhostInTheMachine
                  • Feb 2010
                  • 88
                  To answer your second question, you will have to replaced fuser rollers more often because they are sitting there cooking all day.
                  • Vulkor
                    • Jun 2009
                    • 942
                    He is correct. Just tell the customer they are helping the environment and if they aren't using it once every 4 hours then well geeze lol. Saves you Fuser issues.
                    • msaeger
                      • Sep 2008
                      • 333
                      Tell them to upgrade the thing then it won't take 5 minutes to warm up
                      • Vulkor
                        • Jun 2009
                        • 942
                        True enough this machine this machine is 12 years old and Discontinued in 2000. We only have 1 left in the field and its because its a donation that is used 10 days of the Football Season in a stadium announcer booth.
