C2525 screen calibration
  • gwaddle
    • May 2009
    • 782
    I assume there is a simulation for the calibration of the touch screen but I haven't found it yet. Can someone point me in the right direction?
    I know I should be ashamed of myself. Strangely though, I am not.
  • Vulkor
    • Jun 2009
    • 942
    Software simulation or instructions?
    Taken from a post by D_L_P
    Anyway, to calibrate the touch screen:
    Press Reset (yellow key)
    Press 1
    Press 9
    Press 9
    Press 3
    Press Stop (red key) 5 times
    Now you should see the touch panel menu. I believe it is #1, the top left button to calibrate. You basically touch 2 circles and hit enter or #. Probably a good idea to use a pen or something with a fine point. GL
    • gwaddle
      • May 2009
      • 782
      Thanks that did the trick, but where is that in the book. I'm still trying to figure out the service manual layout.
      • Vulkor
        • Jun 2009
        • 942
        Replacement and Adjustment, Scanner Unit, Touch Panel Position Adjustment pg 177 in Acrobat or 3-27. Just search calibration till you find it. It varies per Service Manual.
        • Iowatech
          Not a service manager
          • 3933
          Also, "#1993 Stop X 5" works, at least on the Lanier variants that I work on, just a thought.
          • Vulkor
            • Jun 2009
            • 942
            Yep as mentioned in Post#2 lol he was just asking where I found it. Have a good weekend.
