Ricoh Aficio SPC811dn
  • tcypy1961
    • 773
    Why would the printer not recognize a toner cartidge? It is a black toner cartridge. Also as a side-note, if this problem occured in the copier version, the Ricoh Aficio MPC3500/4500, would the solution to fix the problem be the same? Any help appreciated, thank you.
  • Vulkor
    • Jun 2009
    • 946
    Is the Toner Cartridge Ricoh brand or some refill off brand? They are supposed to have a chip on them and can only fit in their unique slot. Never heard of one not recognizing the toner.
    • tcypy1961
      • 773
      It is ricoh brand took chip from old cartridge and put on new cartridge; did not work. customer said they've had problems with toner cartridges from vendor where they order before.
      thanks!!!
      • Leif
        • Jul 2010
        • 19
        The RF id chip on the toner bottle contains information of remaining toner in bottle and bottle serial number. So if you re-use the chip the printer will say that the toner i empty or replace toner
        • patrick_aab
          Junior Tech
          • 10
          from what i've had on the copier side to the machine, it could be a fauty toner pump. On the MPC 5000 and i think the 4500s we've had issues with toner pumps failing early.
