Getting files off of a 1027 HD
  • tinfox
    • 317
    The customer has been using this as it should be used (Document Scanner) and now wants to move the files to a computer.
    I have yanked a HD out of one of these yet, but I'm sure there should be a way to pull the docs off by sticking the thing in a USB reader...
    TIA
    tin
  • Choro1dal
    • Jun 2008
    • 176
    If my memory serves me, files stored on the Af1027 in the Docserver are stored in a proprietory format.
    You may be able to plug the drive into an adaptor but you'll only get 1's and 0's.
    If the host machine had a file format convertor you could use that to export the files to a PCinto a more usable format (TIFF/PDF).
    • nmfaxman
      • 1702
      Print them out and scan them into computer, only way I have seen.
      • tinfox
        • 317
        Zoiks!
        • teebee1234
          • Jul 2008
          • 1670
          This is true.....
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            this is called plaY and pluG... hehehe
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              With all the recent commotion about hard drive security, this is actually a really good thing.
              • Venom
                Technical/IT Support
                • Nov 2009
                • 765
                In order to to this you need the "file format converter" option installed in the machine. The documents can then be accessed through WIM and saved to the PC's HD.
                IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
