Aficio 1035 service code SC390
  • hknwbec
    • 214
    [Error Code] Aficio 1035 service code SC390
    Hi
    Could you answer me what is the problem on Aficio 1035 - service code SC 390,Thanks
  • miro
    • Feb 2010
    • 87
    TD sensor or development unit
    • hknwbec
      • 214
      thanks , I try to fix it
      • Leif
        • Jul 2010
        • 19
        How is the dev.roller? if its black after removing the deveolper you hav an faulty dev.roller..you can change the developer and clean the dev.roller and maybe the machine will be usable again or else the td-sensor is defective and than you have to change the lower dev unit..(if you only changes the td sensor you will in short time get an leakage and the developer will spread into the machine...than you are fu...)
        service manual :
        390 C
        The TD sensor output voltage is less
        than 0.5V or more than 5.0V after 10
        consecutive times during copying.
        • TD sensor defective
        • TD sensor not connected or
        connector damaged
        • Poor connection between the TD
        sensor and the I/O board (IOB)
        • I/O board (IOB) defective
        • Toner supply defective
        • Ricoh-ono
          • 340
          My experience has been that the toner bottle is empty and most of the toner in the development unit is depleted. I usually add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
          Do what you can, with what you have, where you are. ~Theodore Roosevelt
          • hknwbec
            • 214
            yes , The problem is solved. the reason is same as ricoh-one.
            • CableGuy
              Impulse Drive Engineer
              • Oct 2008
              • 417
              I had this last week, customer swears blind the machine didn't ask for toner, but the toner bottle was completely empty.....Popped a new toner bottle and Bob's your uncle...sorted...;-)
              • tinnyjay
                • Oct 2009
                • 666
                Originally posted by manuals4you
                This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
                Paul@justmanuals.com
                Your site is down
                "Who loves the roses,must also bear thumbs"
