RICOH 3224C changed "Erase Border" value ?
  • koosol
    • Aug 2025
    Hi guys, I have problem RICOH 3224C
    Now, In SCANNER, that "Erase Border" range value (2mm to 99mm), defualt = "10"mm
    same width "10"
    diff. width "10, "10", "10, "10"
    (1) how to changed defualt value from "10" , to "2"
    (2) how to changed "Erase Border" range value from (2mm to 99mm) to (1mm to 99mm)
    any idea please!
  • koosol
    i'm sorry, any idea how to
    please!
    • Eric1968
      • 2458
      What's the problem with the machine?
      • koosol
        Yes, because when need "Erase Border" that default value = "10"
        I need changed that default value to "2" , same
        Now, Only goto "Erase Border", and ("-") 9 times , goto = 2
        And , do you know if "Erase Border" can support value ="1", because range "2" to "99" mm, NOT "1"
        please!
        • Eric1968
          • 2458
          I don't think you can change default values. They're fixed values in the program of the machine.
          • teebee1234
            • Jul 2008
            • 1670
            I don't believe you can change the minimum value, but you can make something besides the border value =10 as a default.
            • Set the op panel to what you want (erase border value=2 and anything else you may want as default).
            • Select the Program key and save those settings under #10
            • Go into User Tools>Copier/Document Server functions and change "Initial Mode" from "Standard" to "Program 10"
            • Now your default value will be Erase Border=2
            • koosol
              thanks, but do you know that "sp mode" can change default value ?
              • teebee1234
                • Jul 2008
                • 1670
                As was stated previously, we don't think you can change the default value with the sp modes. But if you program it as I stated, you effectively have the same result.
