setting up scan router pro with a 1022
  • mymymydelyla
    • Jul 2025
    I need to setup a 1022 using scanrouter pro on a single pc using window7 or xp...can anyone tell me an easy way? have setup scanrouter years ago but cant remember much now. When I open scan router v2 admin utility it comes up with" select server" ..which ip address goes in here? I have the 1022 set at 10.0.0.9 and the pc set at 10.0.0.1...I think i tried putting in both address and it comes up with "ip address not valid" Can sort of remember how to use scanrouter once I get into it but at this stage cant get past this
  • solorajder
    • Jul 2010
    • 106
    You have to input ip of your computer.
