Lan-fax Aficio 2027 - Cannot send and print at the same time
  • andrewdecruz
    • Jul 2009
    • 74
    Hi friends..
    I hv recently installed a Lan-Fax driver on a computer for a customer using Aficio 2027. The problem is while i can send faxes via the computer using the Lan-Fax Driver, i can't generate a copy of the faxed document when i select the "Send an Print" function.
    Any help is much appreciated...
  • Vulkor
    • Jun 2009
    • 946
    Not seen anything like this before. You installed Lanfax M3 drivers right? Did you check the box in the drivers that the machine has a HDD (Hard Disk Drive). Maybe that would make a difference. Is the machine using USER CODES or some sort of Accounting setup?
    • teebee1234
      • Jul 2008
      • 1670
      Attached is a zipped excel file showing which lan fax drivers go with which model...
      • Vulkor
        • Jun 2009
        • 946
        Yep hangs on my wall. Thus the Lanfax M3 Good reference to have. Not sure how people mess it up unless they just click the wrong model I suppose.
        • Ralph S
          I've seen this before myself, and on other models. I have used the correct Lan_fax print driver. You should look at updating the firmware on the unit. Be aware that the scan to folder to 2003 server is a special mod and is not inclulded in the latest controller, NIB, and scanner formware.
