MP9000 Backdoor Admin Password
    • 8179
    We recently rec'd a used MP9000 from a copier distributor and the default Admin password has been changed. Anyway to reveal what this password is via Service Code?
    User Tools (Hard Key)
    Copier/ Document Server Features
    Admin Tools
    (Menu Protect (greyed out)) Level 2
    Scanner Features
    Initial Setttings
    (Menu Protect(greyed out)) Level 2
    Thanks,
  • Vulkor
    • Jun 2009
    • 946
    try supervisor
    • TonerMunkeh
      Professional Moron
      • 3865
      Yeah, log into web image monitor with supervisor, no password. You can then change the admin password. If the supervisor password has been changed, try this, excerpt from service manual:
      5846-046 - Initialize All Settings & Address Book DFU
      The SP clears all the setting information managed in UCS and address book information (local, delivery, LDAP) and restores these settings to their default
      values. Use this SP to initial the account information (user codes and passwords) for system managers and users as well.
      Note:
      • Be sure to cycle the machine off and on after you execute this SP code.
      • Once this SP has been executed, a message on the screens of applications that use the address book will prompt users that the address book is being
      updated. This prevents the machine from issuing SC870.
      • The machine initializes to determine if the address book is stored on the HDD or on an SD card. In order for the machine to determine whether to recognize an address book on the HDD or the SD card, the machine must be cycled off and on once more to determine whether the machine should recognize the address book on the HDD or the SD card.
      Hit it.
      • Ricoh-ono
        • 338
        Hopefully it is not installed with DOSS. If it is you are hosed. Admin and Supervisor passwords would be changed from default.
        Do what you can, with what you have, where you are. ~Theodore Roosevelt
          • 8179
          No Data Overwrite kit (DOSS) installed.
          Thanks,
          • Vulkor
            • Jun 2009
            • 946
            Ick that would suck. We have only 1 machine with a DOSS unit in it. Not very many paranoid around here I guess. Not sure how one would go about that... guess remove unit per Service Manual and replace NV Ram or HDD? lol
