[CQ] MPC 2500 B/W problems very urgent.
  • nobody-here
    • Mar 2008
    • 237
    Hi all,
    we are having some trouble with a MPC2500 that is having such a big quality unsolved problem.
    The problem appears only in b/w. I cannot explain the problem so i attach the copy counter printing.
    We swapped Dev Unit and Drum Unit with another MPC2000 but no luck. Laser Shutter has been checked along with firmware. They're ok.
    We swapped also other Electronic boards (not the BICU) but no luck. Ricoh Tech (we are indipendent techs) talk about some HDD issue but we're not sure. I read something about NVRAM issue.
    Can You help me.
    thank you very much.
    29 rouge unpair manque.... cous cous....
  • nmfaxman
    • 1702
    Have you checked developer drive clutch or transfer roller?
    • Eric1968
      • 2458
      Almost sure that it's the black development clutch. The old AF3228 series could also produce something like this with defective dv-clutches.
      • nobody-here
        • Mar 2008
        • 237
        Is the developer clutch inside the dev unit? I Will tell my tech guy check this. If have any other clue please tell. Thanks a lot
        • Eric1968
          • 2458
          The clutch is at the rear side of the machine. Replacement is not such a big deal.
          • tcs04
            FORMER Techie
            • 1183
            Originally posted by manuals4you
            This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
            Paul@justmanuals.com
            P.S.... GO AWAY!!!!
            • teebee1234
              • Jul 2008
              • 1670
              This looks like a classic case of the black transfer roller not in contact with the pcu. Have you checked the ITB unit, specifically the black transfer roller? It should always be in contact with the pcu, the colors cam away when not being used.
              • Fearless V K
                • 620
                x2
                Don't take that toner with me!
                • Leonh
                  • Jul 2010
                  • 11
                  have u tried to remove the shutter,the shutter only not the lever actuators.
                  • secretweapon23
                    • Jul 2010
                    • 69
                    most likely, swapped the whole itb unit for faster troubleshooting.
                    Anyone who has never made a mistake has never tried anything new.....A.E.
                    • teebee1234
                      • Jul 2008
                      • 1670
                      That fixed it?
                      • secretweapon23
                        • Jul 2010
                        • 69
                        base on the printed counter attached, looks like 90% came from itb unit, that was said before by teebee1234.
                        check the transfer roller spring for drum black inside the itb unit, if still in good position.
                        please print also ACC to check if the problem came from color black only..
                        thanks,
                        • delosangeles
                          • May 2008
                          • 274
                          Originally posted by nobody-here
                          Hi all,
                          Can You help me.
                          Try this
                          Low image density and or missing images
                          Answer [Cause]
                          The laser optics shutter does not open properly and/or dirty laser dust shield glass blocks or distorts the laser.
                          Firmware bug.
                          [Action]
                          1. Check that Engine firmware is at level 1.11.01 or higher. If not upgrade firmware and recheck image density. If still poor proceed to step 2.
                          • If Engine firmware is below 1.11.01 some field service technicians have had success with:
                            • Check the value of Copy SP Mode 2-914
                            • If lower than try 38 change the value to 38 and recheck image density
                            • If image density is still poor raise to a value of 42 and recheck image density.
                          2. Remove the Laser Unit Assembly and clean the laser dust shield glasses and inspect the laser optics shutters for proper mechanical operation.
                          • Remove the left cover (disconnect the finisher if installed)
                          • Remove the harness cover bracket [B] and rear [C] and front [D] fan brackets
                          • Remove the laser assembly
                          • Remove the shutter assembly
                          • Inspect the 4 shutters for proper mechanical operation, repair or replace as needed.
                          Clean the 4 dust shield glasses.
                          3. Re-insert the laser unit assembly without the shutter assembly and check image quality.
                          • If image quality is still poor the shutter assembly is not the cause.
                          4. Re-insert the laser unit assembly with the shutter assembly installed and check image quality
                          • If image quality is poor repair or replace shutter mechanism.
                          Trade like a tiger sleep like a baby
                          • nobody-here
                            • Mar 2008
                            • 237
                            Thanks to all of you.
                            I apologize for delay but summer holidays delayed everything. (here in sicily, the sand is better than the toner).
                            We solved the quality problem changing the Black Dev Clutch (worked immediately).
                            Laser problem has been checked and excluded from the beginning. Firmware upgraded.
                            Now we have "black toner pump" problem and sc-672 error code. What a mess, but we'll cope with it.
                            We're professionals. :-)
                            Thanks again.
                            Vincenzo
                            • teebee1234
                              • Jul 2008
                              • 1670
                              Props to nmfaxman and Eric1968 for getting it right off the bat.
