Fax problem, Lanier 2005 / Ricoh 5000
  • Travis06
    Tech.
    • 193
    When I manually dial out, fax works. When I use the user presets, it says dialing and doesn't go through. Is there a memory reset on this model? Was working fine until last week.
  • Fearless V K
    • 620
    try fax sp modes there should be a fax memory clear there. I'm pretty sure this will blow away your presets and initial fax settings though so print them out first. Turning off ECM solves lots of problems too if you haven't already done so.
    Don't take that toner with me!
    • ucinn
      • Jun 2009
      • 383
      This might sound stupid, but did they change phone systems. I had a company do that to me and the new phone system, they had to dial a 9 first where they didn't have to before they changed, so had to edit all there presets to dial 9 first.
      • Travis06
        Tech.
        • 193
        I was hoped the problem was just a missing (9) or something to dial out. It's real weird, with the speed dial, it just says "dialing" and never goes away. Ended up swapping fax out with one that had a bad control panel. Moved panels and added speed dials.
        • Fearless V K
          • 620
          if you do need to dial 9 first. sometimes it helps to put a pause or two after the 9 and before the number.
          • nmfaxman
            • 1704
            Is the phone line plugged into the LINE port?
            Did they change DIGITAL phone companies, or is it still analog?
            Stick to the fax basics.
