MP 4000B. Help!!!
  • fotocom
    • Nov 2008
    • 96
    MP 4000B. Help!!!
    Went to an MP 4000B today with SC 544, after investigation the problem almost certainley pointed to the I/O board (as is suggested in the service manual).
    To be sure, I brought the board along to a nearby working MP 4000B, to verify same, before I went and ordered an I/O board.
    What was I thinking..
    All went well I recreated the fault. Great I thought it has to be the board. Returned the working board to the working machine.
    For some reason I decided to do a memory clear without doing an NVRam upload.
    Now I have SC 302 'charge bias leak' on the working machine...
    Followed the manual with all suggestions and I have drawn a blank.
    Is it possible ive shagged the NVRAm by doing a memory all clear.
    What was I thinking, I must have had a rush to the head, any ideas....
    By the way I have manually inputted the machines SP data from its birth cert by to no avail......
  • secretweapon23
    • Jul 2010
    • 69
    have you tried to reset the SC code first? SC 544 is level A SC code, sometimes It can be done just resetting this kind of code rather than to replaced it emmediately.
    Anyone who has never made a mistake has never tried anything new.....A.E.
    • fotocom
      • Nov 2008
      • 96
      Yes I reset the SC code. It was the very first thing I did but it kept coming back. It is deffinitley the I/O board. The problem is I now have SC 302 on a previously working machine, and I am wondering have I caused this by doing a memory all clear.
      • zed255
        How'd ya manage that?
        • 1024
        Why on God's Green Earth did you do a memory clear on a WORKING machine? Have you reset all process values to default and reinitialized everything? Did you perform any service to the engine? I find those PCU's to be real finicky and if you don't get all the bias contacts in place perfectly it won't work afterwards (i.e. do not bend or deform them).
        • Vulkor
          • Jun 2009
          • 946
          I thought 302 was high voltage power supply board
          • secretweapon23
            • Jul 2010
            • 69
            try to swap the whole working PCDU to the machine that having SC 302 so that you may possibly know where's the cause of this SC 302(PCU / high voltage supply board)
            and one thing dont forget to intialized line position adjustment of laser co'z you said you do memory clear.
            • Cipher
              It's not easy being green
              • May 2006
              • 1309
              SC544 is likely to be just a bad thermistor or a blown stat (it will be a fuser related problem).
              Memory all clear...wtf lol, you are lucky you did that on a B&W and not on a color box.
              • fotocom
                • Nov 2008
                • 96
                Ok an update on the problem.
                We had an SC 544,problem turned out to be a blown I/O board.
                Problem 1 solved.
                Then we had an SC 302, problem turned out to be a blown HV board.
                Problem 2 solved.
                Now the machine is locking up and freezing either at start up or during mid copy or indeed in service mode.
                I suspected the Hard drive. Not the problem.I replaced the Hard disk.
                Bear in mind this machine is only 3 weeks old.
                Im now beginning to have my doubts about the controller.
                As for the working machine which i did a memory all clear on (in a momment of madness), that was sorted after inputing all the smc data correctley and initializing everthing. its running a dream again.A close shave!!!
                • tcs04
                  FORMER Techie
                  • 1183
                  Problem 1 solved.
                  Problem 2 solved.
                  MMMmmmm... When was the last time anyone had 2 (3?!) boards blow on a machine??
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Lightning strike possibly?
                    Hit it.
                    • fotocom
                      • Nov 2008
                      • 96
                      Im begining to wonder. Its been while time since i have fitted a board to any of our machines. I dont think I have ever had to put 2 boards in to a machine together. Its a strange one. Especially considering its practically brand new out of it box.
                      • Vulkor
                        • Jun 2009
                        • 946
                        Was the machine on a Grounded Surge Protector? We require that in our maintenance agreements and warranties.
                        • tcs04
                          FORMER Techie
                          • 1183
                          I'm beginning to think we should specify this as well
                          • Vulkor
                            • Jun 2009
                            • 946
                            Give the company an opportunity to sell a surge strip and install it since many don't want to go to the store or forget. Also lets you explain the difference between a SURGE Strip and a POWER Strip.
