Mp 4500 touch screen
  • Tebow83
    • May 2009
    • 92
    Hi guys,
    having a problem with an mp4500 touch screen, its not responding at all, although the number keys and other ones on the control panel all work.
    We swapped the control panel with a working one and the same problem. And the original broken panel does not work on the other machine.
    Anybody any ideas?? Any help greatly appreciated.
    Cheers
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    • TonerMunkeh
      Professional Moron
      • 3865
      H310 9900. The replacement screen for the Apollon and Athena C1 are also affected, B223 9900. Apollon and Athena C2, D029 9900.
      Hit it.
      • tcs04
        FORMER Techie
        • 1183
        Originally posted by tclar
        Hi guys,
        Cheers
        Did you swap the whole op panel unit (Plastic frame, blue buttons) or just the touchscreen?
        • Tebow83
          • May 2009
          • 92
          yeah swapped the whole op panel. The one i swapped it with was working and since it was swapped the touch screen is not working. So now the machine has blown two touch screens.
          • zyqwiz
            • Jun 2009
            • 333
            The one you swapped will be just as old as the original - you need to fit the modified touch panel
            • Tebow83
              • May 2009
              • 92
              the one i swapped was old but it was working before it was swapped. What was the modification made?
              • TonerMunkeh
                Professional Moron
                • 3865
                The glue in several batches of touch screens was defective leading to a huge occurence of panels just randomly dying. The one you need is H310 9900 if it's an MP4500, if it's an MPC4500 (just checking) it's B223 9900.
                Hit it.
                • Leonh
                  • Jul 2010
                  • 11
                  have u tried to calibrate the screen?
                  • secretweapon23
                    • Jul 2010
                    • 69
                    even you swapped the op panel came from working machine do the calibration first co'z still on the memory of machine.
                    c/m - 1993 - c/s x5
                    Anyone who has never made a mistake has never tried anything new.....A.E.
                    • Tebow83
                      • May 2009
                      • 92
                      c/m - 1993 - c/s x5
                      cool, going to try that in the morning.
                      • powshar
                        • Jun 2011
                        • 52
                        Calibration of Ricoh MP 4500 BW Touch screen problems
                        We have an MP 4500 in the field, do we need to replace the touch screen entirely, or just contacts? This is the problem with Touch Screen Calibration.
                        • iMind
                          • Mar 2008
                          • 1116
                          Just order this, part # H310 9900
                          • powshar
                            • Jun 2011
                            • 52
                            Thanks for your help! Really appreciate it.
