Document Server - MPC 2050
  • hmac
    • Aug 2009
    • 129
    On an MPC 2050.
    I save a file on the document server, how can I do to recover this file on my computer via the network? To send it by mail, or to edit, for example.
    Is what I can use the hard drive of MPC2050, as a network hard drive?
    _________________
    HMac.
    _________________
  • teebee1234
    • Jul 2008
    • 1670
    It can't be done unless you install the File Format Converter option. And no, you cannot use the device HDD as a network drive.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3945
      The only thing you can do with files in the Document Server is print 'em.
      Unless you have the File Format Converter, of course.
      • tcs04
        FORMER Techie
        • 1183
        Originally posted by hmac
        On an MPC 2050.
        You can SCAN to your PC!
        • Yetno.0103
          • 63
          Try to download it 1st to ur computer with web image monitor, open browser application on ur computer e.g mozilla firefox or internet explorer, enter ur ip address machine on the adress bar and then login as admin and you can download file what u save on document server to ur computer.
          • teebee1234
            • Jul 2008
            • 1670
            Once again, you cannot download it to your PC without the file format converter option installed. You can view a thumbnail and print it using the WIM, but the image is in a proprietary format, hence the need for the converter.
