Hi y'all.I have a m/c giving vertical lines(magenta and yellow) intermittently.This problem occurred a few days after the ITB was replaced as it was torn.The distance between the lines seems to coincide with distance between the pcu's.Any ideas would be welcome.
ricoh mpc4000 vertical lines.
Hit it.Comment
I'm sorry about not getting back to you sooner about this.I got some info about this fault albeit on a different model.The fix apparently is to check the grounding plate on the itb and replace same if that doesn't work.I removed the transfer belt and made sure any ground was making a secure connection.Because it is intermittent I don't know if that is the solution just yet.I will keep you posted on this 'cos it may be one to look out for.Thanks again for responding.Comment
