PDF printing problem MPC - 2800
  • sabah_karim
    • Sep 2009
    • 67
    Hio
    In on of our mpc-2800 client printing PDF drawing files using PDF format.
    without postscript option. Once they are giving print for more than 150 sheet
    printer stops after 50 pages print.Another A3 drawing file not printing full
    sheet of drawings.
    Can pls let me know that without postscript will i solve problem
    or what other option to do.
    sabah
  • Jomama46
    • 2900
    Adding the postscript will speed it up but wont overcome the file size problem. I dont think there is a RAM upgrade for this model so all you can do is reduce the file size by reducing the resolution.
    sigpic
    A+; Network +; PDI+
    • daveyball
      • May 2009
      • 314
      Sounds like a spooling issue to me, or memory, you shouldn't need a PS option to print PDF's. Has the computer finished spooling the entire print job, before it crashes?
      • Herrmann
        • Jan 2006
        • 792
        maybe some font issue, check the box "print as picture" under enhanced ; makes it slower but helps in many pdf issues
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • jisa
          • Sep 2009
          • 7
          In Pcl 6 Printing Preferences by default Graphics in Print Quality is set to Vector, change it to Raster.
          • secretweapon23
            • Jul 2010
            • 69
            please also check the printer driver version you're using, verify and download new version if not updated.
            Anyone who has never made a mistake has never tried anything new.....A.E.
            • Sashko
              • Oct 2009
              • 110
              Hi,
              Install RPCS printer driver and change setting from "Printing preferences">"Printer configuration">"Job load distribution" to "Shift load distribution".
              If you have a lot of troubles with printing you must change the setting for "Memory usage" from "Frame priority" to "Font priority".
              Sashko
              • Really10
                Print the file as a image
                Print the file as a image, PDF's do layering in the image.
                • rsyarcia
                  Hair Straightener Tech
                  • 711
                  Memory usage-Frame priority to Font priority, will help you.
                  tnx Sashko
                  Nobody is perfect..
                  • mrwho
                    Major Asshole!
                    • 4299
                    Also try with all the driver languages supported by the machine: RPCS, PCL5 (my favourite) and PCL6.
                    Mascan42
                    Ibid
                    • zyqwiz
                      • Jun 2009
                      • 333
                      They are probably getting the application to collate so it is sending 150 times the amount of data rather than collating on the driver - 150 pages to print versus 1 page, print it 150 times
                      • zed255
                        How'd ya manage that?
                        • 1024
                        I had a client who was printing engineering drawings from PDF files and the PCL6 would mess it up, PCL5 would render about half a page correctly and choke completely with both PCL taking forever to render anything, but RPCS was fast with perfect output. I had another where the client was having issues with label alignment and the only driver that worked properly was the Universal PCL6. Don't get hung up on one specific driver, try them all to see which one works best for the client's jobs.
                        Ricoh has been having huge driver related issues of late. Really disappointing to see and I constantly hear 'but my old *insert brand/model here* did it just fine...', which chaps my ass to no end. I heard a rumour that the driver development was farmed out to a third party and that this is the genesis of these crap issues with printing. Any thoughts?
                        • sandmanmac
                          • 3981
                          I had a client that had a real speed issue when printing their PDF drawings, and it would take up to 10 mins to spool a couple of 11"x 17" pages. I updated firmware, tried different drivers, and even a postscript kit. Nothing helped, until I realized that Ethernet speed was set to 100Mbps. I set it to "Auto Select" and problem solved. Just an idea
                          • mrwho
                            Major Asshole!
                            • 4299
                            That reminds me that the opposite (setting it to 100 or even 10Mbps) can help if the problem is caused by some bad network cables and connectors. I had a couple of customers where the machine was slow at auto-select and 100Mbps but worked fine at 10Mbps. Apparently there was a network cable with bad connectors, and since 10Mbps don't use all the connectors, there should've been one of the 100Mbps-only connectors that was bad.
                            One of the customers solved the problem, the other (with a 2045) said "Well, if it works fine, just leave it as it is" to this day.
                            Mascan42
                            Ibid
