Aficio 1232C, Z folds and jams at registration
  • xeroid
    Document Technologies Pro
    • 148
    [Jamming] Aficio 1232C, Z folds and jams at registration
    Cleaned the reg roller, blew sensors and inspected registration area. All looks good. Machine has 100K on it and I am not certain of where or what is the paper loop adj on this machine if any. Any expertise to lend is appreciated
  • Jomama46
    • 2900
    7507 will give you the history of the jam locations and 5804-11 is the output check for the reg clutch
    sigpic
    A+; Network +; PDI+
    • xeroid
      • 148
      7507 shows the last ten all to be 063 jams.
      • Jomama46
        • 2900
        paper stays at the registration sensor
        Did you test the reg clutch? You should be able to hear it click.
        sigpic
        A+; Network +; PDI+
        • Jomama46
          • 2900
          Also you can turn on the fuser motor and the reg clutch to see if the roller is turning.
          sigpic
          A+; Network +; PDI+
          • Smee
            • Aug 2009
            • 178
            Most clutches I have seen tend to be intermittant, so they generally work in the output modes.
            I think its a pretty good chance one of them is knackerd so Id just replace them. Think there is 3 from memory.
            • alliance1
              • Jul 2010
              • 20
              replace both registration clutch and relay clutch right below it.
