HDD/Touch screen relation?
  • Holesaletech27
    • Jul 2009
    • 101
    Hey all,
    I rcv'd a bunch of Ricoh MP2510's in with the HDD removed, and the touch screens are not not working. Is there any relation to this issue, or is it more likely that they just swapped out the op panels(or were bad from the begining)..... I know there are issues with these touch screens, but wasnt sure if the HDD(or lack there of) might be causing an issue as well.
  • zed255
    How'd ya manage that?
    • 1024
    There should be no issue with the HDD removed aside from missing functionality. I've noticed an increase in the number of touch panels we are installing that I'm going to suggest is related to the ambient humidity accelerating the failure of the glue on the touch panels. Bear in mind there are a ton of those that will need the updated panel, you just may need to replace them (just the touch screen, H310-9900, this is the # on the voluntarily issued replacements not the regular order #).
    • tcs04
      FORMER Techie
      • 1183
      Originally posted by Holesaletech27
      Hey all,
      We had a machine (AF1224) which seemed to have a "Black panel"
      It turned out to be a bad controller memory dimm (we think) One of our guys (smartass!) tried the "1993" panel setup and even with the bad memory in the panel would come to life and allow the various tests! as soon as the mode was exited the panel would revert to black.
      With the dimm removed the display would come on and the machine would boot to SC672.
      Worth a try??
      • Vulkor
        • Jun 2009
        • 946
        Worth a try??
        Interesting. Though you wouldn't think it would matter, we had a MP5000 2 weeks old HD go bad. Unplugged drive, but then when machine went to sleep mode it would never wake up lest you turn off machine plug in HD. turn it on, get SC, turn it off, remove HD, boot machine.
        • tcs04
          FORMER Techie
          • 1183
          Mmmmmm.. I'm sure there was a firmware update on various machines for that problem! (Sleep, no wake up) But I agree, it could be the HDD... actually, now I recall an AF2090 which did something similar (freezing at boot) on the first morning after install!!
          • TonerMunkeh
            Professional Moron
            • 3865
            I don't think the MP2510 wasn't included on the touch screen mods list. Anyway, it is a possibility they've robbed the touch screens to get others working, they would possibly fit the Adonis.
            Hit it.
            • Holesaletech27
              • Jul 2009
              • 101
              Thanks for all the info...
              • Radman
                • Aug 2008
                • 24
                Here with a list of all the machines effected ,as you can see the MP2510 model was also efected.
                Design Name
                Ricoh Model
                NRG Model
                Lanier Model
                Infotec Model
                Russian-C4
                Aficio 3025/3030
                DSm725/730
                LD225/230
                IS2225/2230
                Russian-C4.5
                Aficio MP 2510/3010
                MP 2510/3010
                MP 2510/3010
                IS2425/2430
                Adonis-C4
                Aficio 3035/3045
                DSm735/745
                LD235/245
                IS2235/2245
                Adonis-C4.5
                Aficio MP 3500/4500
                MP 3500/4500
                MP 3500/4500
                IS2435/2445
                Themis-C1
                Aficio 3224C/3232C
                DSc424/432
                LD124c/132c
                IS C1024c/1032c
                Emerald
                HQ9000
                CP6346
                Topaz
                HQ7000
                CP6334
                Cat’s eye
                DX4640PD
                DX4640PD
                Athena-C1
                Aficio MP C2000 /2500/3000
                IS C2525/3030
                Apollon-C1
                Aficio MP C3500/4500
                MP C3500/4500
                MP C3500/C4500
                IS C3535/4045
                Athena-C2
                Aficio MP C2800/3300
                MP C2800/3300
                MP C2800/C3300
                MP C2800/ C3300
                Apollon-C2
                Aficio MP C4000/5000
                MP C4000/5000
                MP C4000/5000
                MP C4000/5000
                Neptune-C2
                Aficio MP W3600/2400
                MP W3600/2400
                MP W3600/2400
                MP W3600/2400
                Beluga-C1
                Aficio MP W5100/7140
                MP W5100/7140
                MP W5100/7140
                MP W5100/7140
                • zed255
                  • 1024
                  I know it's affected wether it's on the list or not (which it was on the list I was provided), I've changed a ton on them. Canada wide there was about 14,000 or so panels issued. H310's (mostly) and B223's. There are cases in the branch still awaiting installation but we have been too busy to go at it proactively, so it is fit on failure. Lately that means about two or three per week for me alone.
                  • AyJayAreDii
                    • Jul 2010
                    • 99
                    Where did you get that list Radman... you cold just basically just say they all have the problem
                    We are having a slow call week and yet what we are getting in are touch screen problems.
                    • AyJayAreDii
                      • Jul 2010
                      • 99
                      Where did you get this part number? I don't recognise it from Parts man's or Ricoh web
                      • zed255
                        • 1024
                        That's the part number for the part provided free of charge to address the issue. You cannot order by that number. Order by the parts catalog number if for some reason Ricoh isn't providing replacements in your area.
