nashuatec aficio MPC 2500 touch screen problem
  • Naveed Shahid
    • May 2008
    • 162
    Hi,
    I have problem with precisely fix the icon on touch screen i need to made calibrate can any one give me help how to calibrate touch screen panel
    thanks
    naveed
  • teebee1234
    • Jul 2008
    • 1670
    Press in sequence ....
    • Clear Modes (Yellow Key)
    • 1
    • 9
    • 9
    • 3
    • Clear/Stop key 5 times
    • Leif
      • Jul 2010
      • 19
      it's very likely that your touch screen is broken. If you calibrate the screen and turn the machine off/on you will find that the screen is uncalibrated again..
      • balazs.fried
        • Aug 2010
        • 6
        this is wide spread problem with a range of machines,
        the connector pins on the ribbon cable for the touch panel is getting corroded, and needs to be replaced.
        normally it is a warranty issue.
        • tcs04
          FORMER Techie
          • 1183
          In the UK modified screens are available for a nominal charge.
