Sc 495 error code on lanier ld 075
  • andrew1986uk
    • Jun 2025
    [Error Code] Sc 495 error code on lanier ld 075
    Hello,
    our works photocopier is giving the sc495 error code,Lanier LD 075 is the photocopior, i know the problem is the waste system, i can feel the toner rocks in the tubes, but there are 3 mainboards in the way, anybody got a service manuel or booklet, or any input on a fix, this would be most helpful thanx
  • TonerMunkeh
    Professional Moron
    • 3865
    Switch the machine off. Get yourself a tin of compressed air and blow it about between the big board to the top right and the long metal stripe on the left. Give it 20 minutes before you switch it back on and that should fix it. Failing that, call a tech, it'll need a strip-down and clean.
    Hit it.
    • andrew1986uk
      thanks i'll give that a go, i work for a computer repair shop, so compressed air is plentyful, however if anybody has a service booklet with diagrams in, I'm gonna have a go at stripping it and cleaning, any pointers!
      • jonhiker
        • 661
        Call a qualified service technician.
        Power the machne off and unplug it from the outlet. There are two units in the toner recylce/collection system. Be sure to clean them both out completely, including the sensors.
        • TonerMunkeh
          Professional Moron
          • 3865
          Oh hell no, don't do that. These are classified as high volume machines and are very unforgiving on people who don't know what they're doing. As evidenced by:
          http://www.copytechnet.com/forums/ra...user-post.html
          http://www.copytechnet.com/forums/ri...pc-2500-a.html
          If my original post doesn't cure it, call a tech in. They will give it a complete service and make sure it is running in tip-top condition. Don't forget, if you break it in the course of your meanderings, it will cost you a LOT more to repair.
          Hit it.
          • andrew1986uk
            hi i'm desperate need of a service manuel, my boss wants me to strip and clean copier, anybody got a diagram or summit to work with, esp. those motherboard conections, putting them back anybody got any tips before i got to the shop tommorrow and do it.
            • brodera
              • Aug 2009
              • 106
              If u dont get a tech to do that you sould be carefull when u stripping donw the machine.
              Try to take alots of pics of the bords so u can remember where to put all the things back.
              Basic TIP
              TO andrew1986uk
              • jamesyboy
                toner monkey
                • Jul 2010
                • 188
                this is really not a nice job and not for the faint hearted if you dont do a good job of it it just keeps coming back bes way
                get a service guy in who does these on a regular basis and I would change the pipes bit of a job but do it right do it once !!!
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  A service manual WILL NOT tell you how to strip and clean on this machine. It will tell you what parts need replacing at what times, how to replace said parts and what to do when you replace them. Tell your boss to get a qualified and trained service technician in to do this. Don't forget - you don't have access to any parts if the machine needs them.
                  Hit it.
                  • jonhiker
                    • 661
                    Correct, Sir, This procedure is not outlined in the manual. The best bet is to call a certified tech. They will do it correctly and a basic service and cleaning, as well as alert you to any other issues.
                    The boss should include that he has to pay you do do this job, and not your regular work.
