lanier ld160 error code sc555
  • tlc1234
    • Jul 2010
    • 14
    [Error Code] lanier ld160 error code sc555
    have a lanier ld 160 copier does any one know this error code sc 555 mechanical .
  • TonerMunkeh
    Professional Moron
    • 3865
    SC555 is either a broken thermistor or thermostat. It'll probably need them replacing, possibly a hot roller too.
    Hit it.
    • mikadonovan
      • May 2008
      • 2931
      Could also be just toner buildup on the thermistors. Check if they are both functioning by using SP 1106-001 and 002. A reading of "0" indicates a bad thermistor and must be replaced. If neither are "0" clean them both and and perform a level A reset. If the code returns you probably have a blown thermostat. Continuity check all 3 and replace the faulty one. Redo level A reset and you should be good to go.
      NEVER ASSUME ANYTHING
      • Jomama46
        • 2900
        Also shim the connector in the rear so it makes better contact.
        sigpic
        A+; Network +; PDI+
